Best way to bleed slave cylinder? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-08-2014, 08:18 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
Well I put my throw-out lever back on today and lost all pedal because I had to open my slave cylinder and push the rod back. I was wondering what is the best way to bleed the system. I have a hand bleeder for brakes that you pump with the gauge I got. What is the best way?
bdemutis is offline
post #2 of 7 Old 08-08-2014, 11:21 PM
JSchuricht's Avatar
Mine is a hybrid due to the ZF6 but I found pumping the slave by hand before installing it in the trans worked well for getting the air out.
JSchuricht is offline
post #3 of 7 Old 08-09-2014, 04:21 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 461 Post(s)
You can install it onto the fork and take your hand and push in on the cylinder. Wait a couple seconds and repeat a few times. You should be good
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 7 Old 08-09-2014, 08:03 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Some slaves had bleeders and others did not. Here is the method that worked every time for me: Hang the slave from the line, everything going "uphill". Make sure the reservoir is full. This next part really caused problems for me until I figured this out (so don't think "what the heck would that do ... that's dumb"): Disconnect the clutch master cylinder rod from the clutch pedal linkage. Cycle the slave cylinder slowly by hand 5-10 times. Reclip the slave to the tranny, reconnect the pedal linkage and you should be good. Cheers!
Patrick Feeley is offline
post #5 of 7 Old 08-10-2014, 03:25 AM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
Disconnecting the rod does that make it easier to install the slave onto the fork.
bdemutis is offline
post #6 of 7 Old 08-10-2014, 07:01 AM
Quoted: 15 Post(s)
No, not really. I think it keeps some port from being blocked in the master and not allowing it to bleed. Cheers!
post #7 of 7 Old 08-10-2014, 07:20 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
Well I had to get a new slave cylinder that stupid design ford made with the screw the thing was leaking bad. I'm kind of glad the one I got was only $30 and doesn't have a bleeder screw it was much easier to get a good solid clutch pedal. I just suction bled the line and master with my pump bleeder, and then filled the slave some then left the lid off the master, pumped the slave by had a little decompressed it with the lid off, had my dad screw it on put the slave in place took the straps off and pumped the pedal a few times and she was solid.
bdemutis is offline
