Zf5 won't go into gear.. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-28-2014, 10:15 AM Thread Starter
I have a 96 f350 with a zf5. It won't go into gear when truck is running but when it is off it goes into every gear. If its in gear and I have the clutch pushed down and start it it tries to go forward. Once it's in gear and running you can't get it out. I got my buddy to look at it when I push the clutch in and the slave cylinder goes all the way. The clutch master cylinder slave cylinder clutch flywheel throw out bearing and all that are brand new. The lines bled and has fluid in it. I don't know what to do now. Any help will be greatly appreciated thanks
Hrotan is offline
post #2 of 5 Old 07-28-2014, 10:29 AM
sbluke55's Avatar
Quoted: 527 Post(s)
Garage
It's not fully disengaging. I'd say it's either you have a bent clutch fork or your rod for your master cylinder is different length than your old one. I believe you can pull the rod out of your old master and install it into your new master.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 5 Old 07-28-2014, 10:52 AM
Quoted: 48 Post(s)
This is def. a clutch disengagement problem, not the trans. Does the _fork_ move at least 1/2" when you operate the clutch pedal? Could be the fork is damaged, bent, not located properly, or the throwout bearing not in position.
What clutch kit (presumably the pressure plate is new as well?) and flywheel are installed?
madpogue is offline
post #4 of 5 Old 07-28-2014, 11:02 AM Thread Starter
I got a southbend clutch. Y'all are gunna hate me because I did a cummins swap and got all the conversion from diesel conversion but went to test drive it nd it would not go into gear. They sell a flywheel,clutch and pressure plate from southbend that I put on it
Hrotan is offline
post #5 of 5 Old 04-29-2015, 04:01 PM
SButler83's Avatar
The other thing that can be is the pilot bearing failing, did you get the KEVLAR one from South Bend?
Steve in Central CA
'03 F350 CCSB FX4 w/ 7.3L & 4R100, Factory Tech Valve Body, DP Tuner, AIS Intake, & Banks 4" Monster Exhaust 232K MI
'02 F350 SCSB 4x4 OFF Road w/ 7.3 & 6 speed - DP Tuner, AIS Intake, MBRP 4", F650 Dash Mod, AirLift w/ OBA, 223K MI
'97 F350 CCLB 4x4 7.3 & 5spd. 3-3.5" exh, wayne hanson bumper w/ 12k winch, Nelson rear bumper, Gooseneck, 410K
SButler83 is offline
