Grind when downshift into 2nd - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-27-2014, 08:44 PM Thread Starter
95sorensonOBS's Avatar
OK so I have had this problem since I got the truck. I can't shift into 2nd if I'm over about 10 to 15 MPH. It seems to help of I hold the stick over to the left hard.
95 powerstroke
Ts 6 pos chip
Rosewood stage 1 injectors
Afe intake
3"downpipe
4" straight pipe
95sorensonOBS is offline
post #2 of 3 Old 07-28-2014, 05:48 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
If that is the only gear that it happens with, the synchro is probably going south. I lived with it for a long time on my 94 and then I finally replaced the tranny at almost 250k (it was time for the rest of it). Cheers!
Patrick Feeley is offline
post #3 of 3 Old 07-29-2014, 04:02 AM Thread Starter
That's what I was thinking but wanted a second opinion. Thanks!
95 powerstroke
Ts 6 pos chip
Afe intake
3"downpipe
4" straight pipe
