OD light flashing, hard shift and slipping. NEED HELP WITH DD - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-28-2014, 11:00 AM Thread Starter
So I just bought a 1996 f350 not to long ago. The other day I was driving home from work and went to change lanes and speed up. When I did so it acted as if it was in neutral. Looked down and my OD light was flashing then I let off and coasted and it did it again. Then all of a sudden it stopped. Was fine for about 5 minutes then did it again but this time as the Rpms just really it it shifted extremely hard. I got to where I was going to check the fluid it wasn't low it's bright red. Couple hours later I had to drive home and it was perfectly fine. The OD light stopped flashing as well. Went to leave for work the next day and it acted as if it was in neutral again and shifted even harder but no flashing OD light. I'm new to the power stroke world and need some help as this is my daily driver.
Bear3825 is offline
post #2 of 9 Old 06-28-2014, 06:41 PM
Quoted: 2 Post(s)
Probably worth taking it to a transmission shop to pull codes, but that sounds like it may be getting towards "Needs a rebuilt" time.
The OD light flashing should mean there are codes to pull that will get you more detail on what, exactly, failed. But it sounds like bands aren't engaging properly.
Syonyk is offline
post #3 of 9 Old 07-02-2014, 12:16 PM
Quoted: 4 Post(s)
E40D
I have a 95 F 350 with a rebuilt E40D about 5000 miles ago and never had any problems with it. The other day, though, I was headed up to the mountains unloaded at 45mph tranny temp at 145 EGT at 700 and my OD light started flashing. Had the code read and it said I had one silnode of the three on the modular dead. Getting a new modular on Monday. If I were in your shoes I would get the codes read also.
timlsalem is offline
post #4 of 9 Old 07-11-2014, 07:30 PM
leojr's Avatar
Quoted: 4 Post(s)
I had a rear brake/blinker bulb burnt out and when I hit the left tun signal (to accelerate and pass) the trans would drop out of 'torque converter lock up' and the engine would rev, though not like it was in neutral. This is very common with our truck and transmissions...brake bulbs, blinker bulbs, even the "third light" on the back of the cab, all affect these transmissions. LEDs in any of these positions have to have resistors. It's all about getting the torque converter unlocked to keep the engine running in a panic braking situation. Cheap thing to check.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #5 of 9 Old 10-08-2014, 06:24 PM Thread Starter
So I let the truck sit for about a week since I didn't have time off and then went to take it in and it was just fine. Well last night it did same issue but no light then today had flashing OD light then it went out. Will the code still pull up if the light isn't flashing? If I manually shift into 1st and 2nd it's fine until I shift into D the. It acts like transmission is slipping.
Bear3825 is offline
post #6 of 9 Old 10-13-2014, 03:45 PM
Codes shoud still be in the computer.
syonyk,,fyi, the only band in this trans is a 2nd gear brake band. Only comes on in manual 2 for holding back on a hill.
ipz2222 is offline
post #7 of 9 Old 12-03-2014, 06:15 PM
same problem
hey bear did you get the trans problem figured out? I've had a very similar problem, when its cold it shifts fine but as soon as it gets to operating temp it refuses to shift into 2nd gear, if I put it in 2nd gear it shifts to 2nd and then I can put it in drive and everything is fine (if I don't put it in 2nd gear and let it shift normally it has to get to 3200 rpms then it shifts to 2nd REAL hard) until I come to a stop and the whole process repeats, but on my way back from LAX the overdrive light started blinking, everything seemed to be fine @ 60 mph so I came home (about 60 miles). I puled the overdrive light (blinking light) apart and found a broken wire and repaired it and no more blinking light but the shift problem still persists. so if you found ur problem just maybe it will solve mine. I used to work for Chrysler in my younger days & have built a few trans(mopar,chev) but no ford. I'm looking into doing it again. I haven't heard a lot of good about these trans but for what they do I think they do ok. Hang in there, Jrods245
jrods245 is offline
post #8 of 9 Old 12-03-2014, 06:20 PM
blinking light
I got the same but I can't pull codes, 97 in a 92, they done a good job can't tell unless you look at valve cover. did the new solenoid fix the prob? Jrods245
jrods245 is offline
post #9 of 9 Old 12-04-2014, 10:01 AM Thread Starter
To be honest I haven't messed with it. I let it sit for week when I was out of town and it has been fine since.
Bear3825 is offline
