Transmission Cooler Line Part Number - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-24-2014, 07:01 PM Thread Starter
I just purchased an obs and have had a bad start so far, the power steering pulley cam off and then the belt pulled the rubber line of the transmission cooler line coming from front of transmission. It also bent the metal line up and against the block. Anyone have a part number for this line figured I might as well go ahead and replace that rather than put it back together to find a leak from being bent.
Only spent a few minutes looking before I had to leave. I also noticed that there is either a part of the belt or hose stuck behind the fan pulley so got to figure out how to get that out still. I also saw there are also 3-4 wires showing in that area as well, they dont seem to be tore up just out of the protective sleeve so hopefully I didnt get the CPS wiring hooked up on the belt.
cory99 is offline
post #2 of 8 Old 06-25-2014, 01:57 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Get a piece of 5\16 steel brake line and make your own. Mine were shot when I got my truck, took all of the old ones out ran new steel lines to a remote cooler in front of the radiator. The flare on the brake line fits in the fitting on the trans.
dirtcrew51m is offline
post #3 of 8 Old 06-25-2014, 07:36 PM Thread Starter
Thanks I'll try that route. Got to look at it again tonight and it tore all the split low off CPA wiring but the wires are in tact thankfully. Howeve i do got part of the belt wrapped under the balancer so have to try and get that all out.
cory99 is offline
post #4 of 8 Old 06-25-2014, 07:40 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Another alternative would be to upgrade to the 3/8" SD lines:
Transmission Cooler Lines (SuperDuty 3/8”)
(Ford) Line F81Z-7A031CE
(Ford) Line F81Z-7A030CA
(Ford) By Pass Tube 2C3Z-7H322-BA
Cheers!
Patrick Feeley is offline
post #5 of 8 Old 01-28-2015, 03:59 PM
I know this thread is alittle old but Patrick I was wondering if those 3/8 SD lines would work on a 97 450 and are they a exact replacement or would I have to alter them a bit. Thanks
Jax50 is offline
post #6 of 8 Old 01-28-2015, 05:35 PM
Quoted: 13 Post(s)
They should work fine (from what I've read). You would probably need to change the hose parts to the radiator cooler and air cooler too. Cheers!
post #7 of 8 Old 01-29-2015, 03:32 AM
OK Great. Ill give it a shot.... Thanks
Jax50 is offline
post #8 of 8 Old 02-07-2015, 05:13 AM
leojr's Avatar
Quoted: 4 Post(s)
What does the bypass tube do? There isn't one on it now, is adding one important?
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
