ZF5 2nd gear downshift issue - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-17-2014, 03:01 PM Thread Starter
pk64f100's Avatar
Truck will not go into 2nd while moving must stop to put in 2nd but runs great other than this issue. i am about to buy but do not want to spemnd another $2k to fix trans right away. Anyone help truck is $5,ooo with no rust crew cab and 7.3
pk64f100 is offline
post #2 of 8 Old 06-17-2014, 06:11 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
It is probably the synchro ring (it was on mine) if it is that bad and all other gears are fine. Cheers!
Patrick Feeley is offline
post #3 of 8 Old 06-17-2014, 06:19 PM Thread Starter
pk64f100's Avatar
How much and how bad
Was it expensive and how long do they last till trans just isnt able to go anymore. or is it just an anotying thing, i could live with that for awhile.
pk64f100 is offline
post #4 of 8 Old 06-18-2014, 08:29 PM
Quoted: 13 Post(s)
Its more of an annoying thing (at least it was for mine) so if you can live with it, you should be good for awhile. For me, I needed 2nd when towing the trailer (empty was no problem) at low speeds and downshifting got near impossible. I bought a ZF-factory remanufactured unit for $1800. You could probably have yours rebuilt for a lot less. Cheers!
post #5 of 8 Old 06-19-2014, 12:45 PM Thread Starter
pk64f100's Avatar
Thank you
I appreciate your time, I have found $1550 for remanufactured trans doesn't seem too bad to swap out, I think i could do myself.
pk64f100 is offline
post #6 of 8 Old 06-19-2014, 06:36 PM
Quoted: 13 Post(s)
If you can get or borrow a tranny jack, it is very helpful. The trannies are fairly heavy. I found it easier to remove the shifter and the stub (just don't lose the square white plastic bushings down into the tranny when you take the shifter stub out). Cheers!
post #7 of 8 Old 06-24-2014, 04:00 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The rebuild kit(bearing, syncros an seals) is about $250. So 1500 for a "reman" is a rip off to me. My trans guy charges me $450 to hand him a ZF and rebuild it
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #8 of 8 Old 06-24-2014, 05:01 PM Thread Starter
pk64f100's Avatar
Thanks for info
Yeah, that sounds more like it. They not too bad getting in and out I've been told.
pk64f100 is offline
