2nd to 3rd hangs up - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-13-2014, 10:07 PM Thread Starter
BR'sCrewCab's Avatar
2nd to 3rd hangs up
Any ideas as to why the transmission will hang up between 2nd and 3rd? 1st to 2nd is crisp, then at about 2300 rpm the trans will down shift about 150 rpms hold for a second and then drop the rest of the way into 3rd. It almost feels like a 5 speed trans. I sent my chip back in since the rebuild thinking that would be the issue, but it does the same thing. Not knowing much about trans,I assume it is the valve body????
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #2 of 2 Old 06-17-2014, 11:57 AM Thread Starter
Well, I am an idiot. I spent the last couple of hours learning how a torque converter works. The second drop in RPM is the TQ lock up.
