P1728 need help e4od problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-13-2014, 11:26 AM Thread Starter
Chaas312's Avatar
I bought a 97 f-250 4x4 only 67xxx miles but having trans problems, 1st shifts fine 2nd gear runs up past 3k then slams into 3rd and fully locks the torque converter in so the truck falls on its face, once I get speed up it will shift to o/d when the brake pedal is lightly pressed (just enough to send a brake signal) then when i slow down it doesn't downshift and the converter stays locked right until it's about to stall them downshifts back to 1st, my question is is my trans shot, it shifts and pulls good in 1-2 is it a solenoid or just the converter shot? I have access to snap on scan tools is there anything I need to check also mechanically inclined and have the tools to do myself I'm just not familiar with transmissions I had one code on it p1728 trans slip error converter clutch fault.. And help or advice would be greatly appreciated
Chaas312 is offline
post #2 of 3 Old 05-15-2014, 05:29 AM
nra1ifer's Avatar
Since this is a new-to-you truck, the first thing I would do is a complete transmission service; drain everything including the TC, replace the filter, then fill it with new fluid..... then see how it does.
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
“I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.”
nra1ifer is offline
post #3 of 3 Old 05-15-2014, 06:03 AM Thread Starter
Chaas312's Avatar
Yeah I've changed all fluids and filter still does the same thing
Chaas312 is offline
