'97 F350 wont move. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-20-2008, 09:59 PM Thread Starter
JIMCO1958's Avatar
'97 F350 wont move.
I just finished servicing my powerstroke and cleaning up some odds and ends under the hood. Started the thing up and it runs great and sounds good. I let it idle for a while to get it up to temp and get the new antifreeze mixed up. About 30-40 min. Went to pull out and go mount my plow and the truck would not move. Forward, reverse nothing. Tried shifting the transfercase and nothing is moving. I checked the trans fluid and the stick was dry. Added fluid but still no movement. Did I burn out the trans pump while idleing with no fluid in the trans? Is there a way to check the pump pressure.The trans was on its way out but it did work. Now nothing. Any advise would be helpfull. Thanks in advance.
JIMCO1958 is offline
post #2 of 4 Old 01-18-2009, 02:38 PM
Shade tree mechanic
95dieselsmoke's Avatar
bumping this up. mine is doing the exact same thing after injectors installed... did you get it fixed? what was it?
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #3 of 4 Old 01-18-2009, 04:57 PM Thread Starter
JIMCO1958's Avatar
Well, I let it sit for a few days. Went back to it, started it up , put it in gear and it drove off. Has been working fine ever since. Im still waiting for it to quit on me when I least expect it. So far everthing is working (knock on wood).
post #4 of 4 Old 01-18-2009, 09:01 PM
Shade tree mechanic
wierd, ok. thanks alot man
MATT
