Screeching noise. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-26-2014, 08:59 PM Thread Starter
sethc24's Avatar
Screeching noise.
Hey guys i just finished a 5 speed conversion on my truck. New LUK clutch,, throwout bearing, clutch fork. I put lithium grease on the input shaft, bearing face and clutch fork pivot pin. With the transmission in neutral and the clutch pedal released there is a screeching,creaking noise coming from inside the bellhousing. It will disappear if i push or pull the clutch fork up or down. What should i be looking at and if its the pivot pin can it be replaced with the transmission bolted up?
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #2 of 3 Old 05-24-2014, 07:46 PM Thread Starter
sethc24's Avatar
Okay after some more money and figuring out i have fixed the screeching problem. LUK put the wrong throwout bearing in the kit. Bought a throwout bearing from ford ( much heavier, fit nice and snug.). And installed the input shaft end repair kit and the screeching is all gone now. Also a new pivot pin and master/slave assembly.
sethc24 is offline
post #3 of 3 Old 06-07-2014, 08:28 PM Thread Starter
sethc24's Avatar
Okay an update on this. Drove the truck for a week, thinking the screeching/squeaking issue was fixed. Its started doing it again. Now the shift fork i am using does have some damage on it from using the wrong throwout bearing. I also installed a zf-5 input shaft repair kit as well while i had the transmission out again. Does anyone have any ideas as too why the screeching has started again?
sethc24 is offline
