1995 e4od gear selector won't go into park - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-11-2014, 09:04 PM Thread Starter
My gear selector for my truck has always been stiff to change gears but today I went to put in park and my gear selector will only move to reverse then I went back to drive and tried again now it will only go to neutral.. Is there a way to adjust the gear selector? And also adjust it to make it easier to change between gears? My truck is currently parked in neutral with the E brake on.. Thanks
nwatson is offline
post #2 of 4 Old 04-12-2014, 04:02 AM
Chop's Avatar
Take a look underneath the steering column and you will see some gold colored torx bolts , I'll bet they are loose or about to fall out
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #3 of 4 Old 04-12-2014, 11:19 AM Thread Starter
the bolts are tight. i unhooked the cable from the trans and when i click the manual lever on the trans into park my cable is about 1/4 to short to hook on? is my cable messed up?
nwatson is offline
post #4 of 4 Old 04-12-2014, 11:23 AM
Matthew82's Avatar
Exactly what happened to mine.
Originally Posted by fordmandan87 View Post
Matt are you on the sauce?
All 3 at the same time? Who do you think you are, Charlie Sheen
Matt the odds of you convincing the guy he's not in possession of a kryptonite vagina that commands top dollar for the hour is lower than me getting to bang a millionaire midget on mars during a meteor storm
Matthew82 is offline
