Tranny Slipping then banging into gear 1-2 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-08-2014, 04:48 PM Thread Starter
Exclamation Tranny Slipping then banging into gear 1-2
I have a 1997 F350 E40D 4WD regular cab long box.
So I have been trying to diagnose a problem I have with my truck.
Under hard acceleration half pedal or more, the 1-2 shift slips, then slams into gear. If you let up when its ready to shift it doesn't do it. I unplugged the batteries and let it reset and drove it and it didn't do it for a while then started doing it again. If I manually shift from first to second it shifts smoothly. Any ideas? Speedo is working, all tail lights and cab lights are working, fluid is red and doesn't smell burnt. 167K miles second transmission in the truck.
Don't have a job and going back to college really hoping I don't need a new transmission right now!
twducz1 is offline
post #2 of 4 Old 06-08-2015, 06:39 PM
AMM2046's Avatar
Did you figure it out? I have that problem.
AMM2046 is offline
post #3 of 4 Old 06-16-2015, 06:47 AM
Quoted: 3 Post(s)
Mine used to do the same thing, tranny guy said it was probably just a stuck valve in valve body, told him to build the whole thing up anyways, ended up having absolutely no clutch left on 2nd gear and plates worn thin, surprised I even got it there.
Cyanide is offline
post #4 of 4 Old 06-16-2015, 03:23 PM
Vannnce's Avatar
Quoted: 13 Post(s)
Sounds like shift flare, my tranny has done it since brand new. I believe a new valve body will stop it
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
