1st-2nd gear and od wont turn off - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-08-2014, 01:17 PM Thread Starter
KS_
Quoted: 22 Post(s)
So now my lovely truck won't shift into second unless I let of the pedal. Also when push the od button to turn it off it wont work? It just acts like it will and stays in od... any idea whats wrong? Tranny has been rebuilt but it has less than 100k on it.. problem is I they only had a 18 month warrenty and its been just under 2 years as of now.
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #2 of 6 Old 04-08-2014, 02:00 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Sounds like a sticking solenoid or valve body, maybe a piece of gasket material hung in something. Fluid dark or have a burned smell to it? When was last fluid and filter change? Any metal bits on the magnetic plug?
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
post #3 of 6 Old 04-08-2014, 03:51 PM Thread Starter
KS_
Quoted: 22 Post(s)
Havnt actually took off the plug yet or anything. Transmission was replaced at 515 and its at 560 now. So 45k ago it was all new. I was told it may be the accumulater regulator valve? Im just trying to see if it could be something stupid before I have to make any decisions.
KS_ is offline
post #4 of 6 Old 04-08-2014, 04:00 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Trans fluid and filter need to be changed every 15 to 60 k miles, depending on what you do with it and how well the cooling system works, and the color, smell, and any metal content in the fluid tell you a lot about the condition of the internals.
IN-LAWS...
post #5 of 6 Old 04-08-2014, 08:49 PM Thread Starter
KS_
Quoted: 22 Post(s)
Okay. So should I flush it and change the filter? I know that probably wouldn't solve the problem but it would probably tell me what may be wrong by looking at what comes out with the fluid like what you said?
Sorry this whole transmission thing is new to me. I try to just know what I need to.
KS_ is offline
post #6 of 6 Old 04-10-2014, 09:36 AM Thread Starter
KS_
Quoted: 22 Post(s)
Trans shop said I had a shift solenoid b code. So should be a 500 dollar fix.
KS_ is offline
