How to replace The Rear Speed sensor?? - Ford Powerstroke Diesel Forum
Old 11-14-2008, 08:01 PM
Hey guys, having the normal problems with my auto Trans (man 5 spd is looking better and better) Got under it tonight and removed wire from the VSS and unbolted it but i can't get the damn thing out of the rear end.... any tricks guys?
Its a 97 PSD auto 2wd, when it is wet out it goes a couple of miles and the o/d light starts blinking and it does the limp mode, i want to clean or replace the sensor but i can't get it off.
Any help is appreciated!!!
Old 11-14-2008, 08:19 PM
Old 11-18-2008, 10:20 PM
Send a message via AIM to Maverick1701
Once you unplug the wires there is one bolt that holds the sensor in take out the bolt and the sensor its probably a little stuck in there so pry it out. Its a cheap sensor if I remember right autozone didnt carry it when i replaced mine I had to go to ford. Its just a magnetic pickup sensor, no gear like the old fords when they were on the transfer case. It picks up a signal from a small ring gear in the diff.
Old 11-19-2008, 05:54 PM
yeah its just slipped in there, has an Oring that might have swelled, just ory on it until it pops out.
