Won't move when cold - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-14-2014, 03:56 AM Thread Starter
Today when I went to go to work I started up my truck it was -10 out. It started fine and everything, but when I went to put it in reverse it just revved up and didn't didn't move. So I put it in drive and the same thing happened. So I put it in park walked around the truck. Not that was going to help anything. So then I get back in put it in reverse and it worked fine. It drove fine all the way to work so I'm not sure what is going on. I did a brake lock with breaking the tires loose to see if the torque converter would hold rpm and that seemed fine. Any ideas?
letrbuk is offline
post #2 of 11 Old 02-14-2014, 05:26 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well hell think about it at -10 the oil in the tranny and engine is like glue so sometimes it takes a few seconds for the tranny to catch and reduced power of a cold arse engine may not have had the torque to move much at low rpms. Did you start it and immediately try to drive because thats terrible for the engine and tranny.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 11 Old 02-14-2014, 05:49 AM Thread Starter
I can try letting it warm up longer before I move it. It didn't do this when it was -30 though. I move it pretty quickly after start up as I don't want the whole garage filled with exhaust.
letrbuk is offline
post #4 of 11 Old 02-14-2014, 05:56 AM
Chapter Director
Quoted: 5 Post(s)
Just crack the garage door and you should be fine especially if you have the tailpipe pointed towards the door. You dont have to let it run very long but enough to get fluids all circulated and it should help. I use the glow plugs as a timer in a sense that if im in a hurry i wont ever drive until they shut off. It helps i have mine hooked to leds but you can tell when they shut off by your volt meter on the cluster. Thats like my "minimum run time"
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 11 Old 02-14-2014, 06:00 AM Thread Starter
That's a good idea with watching the voltmeter for the glow plug shut off. I'll do that in the future. Hopefully it works. As I said earlier it drove fine otherwise it just didn't want to move cold.
letrbuk is offline
post #6 of 11 Old 02-14-2014, 06:06 AM
Chapter Director
Quoted: 5 Post(s)
It should its very obvious when it goes from the n-o to like the a-l on the "normal" on the gauge. Yea thats normal at those temps, think about it this way do you want to go out and start running full speed at -10
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 11 Old 02-14-2014, 07:58 AM
Quoted: 50 Post(s)
NEVER start ANY vehicle engine that burns hydrocabons in an unventilated garage with the door closed. Not even for a few SECONDS. You don't want to know how I know....
+1 on the GP run time; coincidence, but it's a good easy guide for warm-up time.
madpogue is offline
post #8 of 11 Old 02-14-2014, 08:04 AM Thread Starter
I always have the door wide open. The exhaust just seems to like to collect in there.
letrbuk is offline
post #9 of 11 Old 02-14-2014, 08:52 AM
Quoted: 50 Post(s)
Tail end toward the door, or vice-versa?
madpogue is offline
post #10 of 11 Old 02-14-2014, 09:01 AM Thread Starter
Tail end towards the door.
letrbuk is offline
