Can I plug e4od cooler line?? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-10-2014, 01:44 PM Thread Starter
I have a pretty bad leak in what I think is a cooler line on the passenger side right by the down pipe. it is leaking right at the fitting. can I put a plug in it till a new one comes from lmc??
97 F350 CCLB Rifraff 6637 intake, 4 inch exhaust, 203 T-stat, Beans electric fuel system, PHP Hydra chip, triple disk converter
turbodieself350 is offline
post #2 of 2 Old 02-10-2014, 06:19 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
No, unless you want to risk damaging your transmission. Cheers!
Patrick Feeley is offline
