Two Things on my E40D - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-24-2014, 08:36 PM Thread Starter
I don't know if I have problems or not.
1. My Autometer transmission temp gauge eventually pegs out at 250 regardless of the ambient temp. The factory temp gauge stays at about mid point on scale. The fluid looks good and the surface of the transmission isn't hot to the touch. I suspect I may have a bad sensor or I have it in the wrong location. Any ideas on how to trouble shoot this.
2. I had a strange experience one day while trying to climb a steep drive way. My tires started to spin so I let off and rolled back and gave it another go and ended up spinning again. I backed down to a point that I could get a running start. When I hit the peddle I got a lot of RPMs out of the motor but I got very little of moving forward. Kind of like being in 4 wheel low, but in a really low gear. I let off and waited a bit and hit the peddle again and everything was back to normal. Could this be a foreshadowing of major problems?
35" Falken Wild Peak
18" Chrome Wheels
5" Stainless Magnaflow Exhaust
6637 Intake,
Auto Meter 7072 Triple Gauge Pillar Kit
Wicked Wheel 2
DP-Tuner F5 W/ 60, 80, 100, 120 HP tunes
Full Force Single Shot 160cc Injectors
John Woods Valve Body
International Bellows Up Pipes
SensibleHeat is offline
post #2 of 4 Old 01-24-2014, 10:54 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
That sounds like your temp gauge is off, The trans wouldnt work at that temp
Sounds like the coast clutch might have been slipping. Obviously its a sign of wear. How many miles are on it?
Trucks and parts............
kanuck15 is offline
post #3 of 4 Old 01-25-2014, 05:58 PM Thread Starter
It has just over 143K on it.
18" Chrome Wheels
6637 Intake,
Wicked Wheel 2
post #4 of 4 Old 01-25-2014, 06:48 PM
kanuck15's Avatar
Quoted: 10 Post(s)
Id go ahead and say you are looking into a rebuild in the future. If its free revving in gear thats an issue
Could be as simple as a torque converter but it could also be a full rebuild
kanuck15 is offline
