Manual fluid change - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-04-2014, 11:17 AM Thread Starter
Manual fluid change
So changing the fluid in my 95 5 speed. What fluid? Read synthetic ATF? What kind and how much? Thanks
8my$ is offline
post #2 of 3 Old 01-04-2014, 12:19 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Synthetic ATF (Castrol TranSynd is what ZF factory remans use), 3.6 quarts (roughly if you are using the fill plug on the side). Some guys just pour 4 quarts through the shifter opening. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 01-04-2014, 01:39 PM Thread Starter
Perfect. Thanks
8my$ is offline
