E4OD woes - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-26-2013, 07:28 PM Thread Starter
E4OD woes
So, I was driving back to washington from montana, and my speedometer starts flopping all over the place. Easy fix, vss sensor right? well I went to the next napa and got a new sensor, only to find out the pigtail was messed up, causing the erratic signal. I found a new pigtail, 75 miles away at another napa, so i started driving, as soon as I got back on the highway, my od light starts flashing, and send the tranny into "way to high line pressure because im slipping" mode, now I know that these trannys don't survive long with the od light flashing, but I continued driving because I had no other option. Long story short, I replaced the pigtail, disconnected the battery cables for 15 min, and drove like 200 more miles home without an issue, or a flashing od light.
But, now my fluid is significantly darker, and I'm wondering how much this e4od has left? It is shifting fine, like it always has, but I'm worried when the trans went into "oh sh*t" mode it damaged something.
I was considering dropping the pan and swapping the filter, or maybe doing a complete fluid flush, but I'm worried since there is so much material in the fluid now that its just gonna slip if I flush it out.
What do you guys think?
andrewu6 is offline
post #2 of 3 Old 12-26-2013, 07:51 PM
nra1ifer's Avatar
First place I'd start would be a complete flush, including the torque converter, new filter, and add a magnetic filter to the return line coming from the radiator/cooler.. like this one http://www.amazon.com/Raybestos-Magnefine-Magnetic-Automatic-Transmission/dp/B0065LZA94%3FSubscriptionId%3DAKIAILSHYYTFIVPWUY6Q%26tag%3Dduckduckgo-d-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB0065LZA94
Then see how it acts.
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
nra1ifer is offline
post #3 of 3 Old 12-26-2013, 08:07 PM Thread Starter
Heres where I'm at with it, I"m driving back to montana next sunday. I dont want to do a flush, and then the trans decides to start slipping halfway home because so much clutch material is gone. regardless, the trans will be getting rebuilt when I get back, Should I flush the fluid, and try and get a bunch of miles on it before I head back, or do should I just drop the pan do a filter, and hope for the best. I only need like 1200 more miles out of it haha
The darn thing is shifting good still, it almost feels better then before the od light started flashing. The change in fluid color is just whats really worrying me. The fluid was a little dark before, but didnt smell burnt, but I figured it was old fluid since I just got the truck. now it almost looks like used motor oil!
andrewu6 is offline
