95 5-speed tranny seals going bad - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-23-2013, 02:52 PM Thread Starter
juniperforest83's Avatar
I'm a new diesel owner and don't know a lot about transmission stuff.
I got my truck back from getting the oil changed and a general inspection. Mechanic said the tranny was low on fluid and it is pushing through the rear seal. Said he had to drain some out of the transfer case and that it needs serviced. He had a list of other things that need addressed so it was kind of a whirlwind of information to take in. Hope this is enough info.
He didn't get into details with me, just told me I would need to bring it back to get the tranny serviced.
If the seals are bad do I need a tranny rebuild or is it more of a simple thing to replace the seals. The tranny shifts well, no grinding and doesn't appear to have any issues going on that I can tell.
I plan on taking it to get some mods done by a buddy's mechanic, but it is 600 miles away. Is this something that can make that far and hold up?
1995 F-250 XLT EC 5-Speed 7.3L 340K & Stock for now....
juniperforest83 is offline
post #2 of 8 Old 11-23-2013, 06:11 PM
dr.deere's Avatar
Quoted: 19 Post(s)
if the trans is draining and filling the transfer case there is actually two seals that would need to be replaced. the output shaft seal on transmission and the input shaft seal on transfer. I believe the output seal can be replaced without diassembling trans. the input seal if I remember correctly needs to have the transfer case halves separated a trans rebuild will not be necessary as long as synchros are good and what not
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 8 Old 11-24-2013, 01:21 PM Thread Starter
Okay great! Thanks for the information. That helps a ton! I'm pretty sure the syncros are good.
Are the seals something that get progressively worse? I'm just wondering how much time I have until I get them replaced. It only gets driven a few times a week.
post #4 of 8 Old 11-24-2013, 01:51 PM
dr.deere's Avatar
Quoted: 19 Post(s)
They might leak worse they might not keep an eye on levels and run it until you can fix
Sent from AutoGuide.com App
dr.deere is offline
The Following User Says Thank You to dr.deere For This Useful Post:
juniperforest83 (11-24-2013)
post #5 of 8 Old 11-24-2013, 02:49 PM
Quoted: 53 Post(s)
How was it determined that the fluid in the transfer case had come from the transmission? The odds that the output shaft seal on the tranny and the input shaft seal on the t-case are both bad, AND that there would be nothing leaking externally from the joint between them, is close to zero.
The transmission and transfer case are mechanically no different from those behind a gasser engine.
madpogue is offline
post #6 of 8 Old 11-24-2013, 03:54 PM Thread Starter
The mechanic said the transmission was low by two quarts...so I think that's how he determined it.
I probably won't take it back to him as I asked them to just look at my dead tachometer & they fixed it without calling me first. Needless to say my bill was $112 more than I was quoted for the basics. So I don't know if I can trust his opinion.
post #7 of 8 Old 11-24-2013, 09:03 PM
Quoted: 53 Post(s)
Yeah, he has no proof of the tranny fluid level. What on earth was he doing anywhere near the tranny if all he was doing was diagnosing a tachometer issue?
madpogue is offline
post #8 of 8 Old 11-25-2013, 07:07 AM Thread Starter
@madpogue "Yeah, he has no proof of the tranny fluid level. What on earth was he doing anywhere near the tranny if all he was doing was diagnosing a tachometer issue?"
This was my first post in the thread:
