1997 ZF5pd problem - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-22-2013, 05:48 PM Thread Starter
1997 ZF5pd problem
hey guys I am in need of help BADLY. 1997 F-350 SRW ZF 5SPD. I just put a south bend stage 2 clutch kit in, due to old was throw-out bearing was bad. I upgraded due to future power upgrades. when driving in low rpms i have a grawl noise,when i get to 4th and 5th gear the higher range or highway speeds it sounds like a piston rod is about to come loose. I got a new clutch fork from Ford and changed the fluid with mobil1. the grawl at lower rpms is quieter but not gone and the highway speed noise is still there. I jacked up the rear end and ran to 40 mph and hardly no noise. These noises WERE NOT there before I changed the clutch. I did noticed that if I hit a bump in the road the noise will stop just for the duration of the bump and thats all HELP HELP HELP!!!!!!! I kinda need to fix this ASAP due to it being my daily driver
diesel317 is offline
post #2 of 2 Old 11-09-2013, 06:25 AM
I'd check to see if your down pipe is touching cab at the pinch weld on floor pan fire wall area. Also wondering if your tranny at the shift tower is touching the cab? Sounds to me like you have a part of the drive train touching and vibrating against the cab. I'll bet it's the DP.
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
