97 F350 Auto to Manual swap - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-22-2013, 05:41 PM Thread Starter
I've done this in other vehicles before. The biggest questions I have are is it a hydraulic Master/Slave cylinder system? Will the Auto transfer case bolt to the Manual trans? If so what about a 2wd manual trans? Will I have computer issues? Any other advice you can think of would be greatly appreciated. Thank you.
ramchargerjay is offline
post #2 of 9 Old 10-22-2013, 10:47 PM
JSchuricht's Avatar
Yes, it is a hydraulic master/slave system. The auto transfer case will bolt up but the linkage will need to be shortened/replaced. A 2wd trans will work but you need a different tail section to mount the transfer case. The computer will work, some people have minor issues like romping on startup or a miss at higher RPM. You can get the PCM reprogrammed or get tunes for a manual trans to fix these issues. Or of your like me and already had romping on startup then it may go away with the manual trans.
Before you mount the new clutch/brake peddal, look into converting the clutch master rod to a heim joint, the stock setup is not all that durable.
JSchuricht is offline
post #3 of 9 Old 10-23-2013, 04:47 AM
Quoted: 53 Post(s)
For the hydraulics, you can get a complete pre-built pre-bled sealed kit. MUCH easier to install, no bleeding.
BEST way to manual swap is to have a donor truck. If you go that route, swap over the hydraulics as a complete assembly, and keep the slave below the master.
madpogue is online now
post #4 of 9 Old 10-23-2013, 05:02 PM Thread Starter
What about the driveshaft length?
post #5 of 9 Old 10-23-2013, 06:36 PM
Quoted: 53 Post(s)
Rear driveshaft will be longer; front driveshaft will be shorter.
post #6 of 9 Old 10-26-2013, 10:08 AM
PSDprepper's Avatar
I just did a zf5 swap on my truck , i have the proper length front driveshaft, Im afriad to put it on though because it looks like the crossmember isnt deep enoguh to clear the driveshft..anybody run into this issue before?
- Tyler
PSDprepper is offline
post #7 of 9 Old 11-09-2013, 06:38 AM
PSDprepper wondering if your driveshaft has the constant velocity joint on the T case end? To OP I think the easiest way to do this is buy a parts truck and swap parts over, then sell off what you don't need.
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
post #8 of 9 Old 11-09-2013, 07:52 AM
Quoted: 53 Post(s)
Did any of our trucks have a CV joint anywhere in the driveline?
post #9 of 9 Old 11-09-2013, 08:29 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
i think he means a double cardan joint
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
