E4OD probems, can't find anything similar searching, HELP.PLEASE! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-20-2013, 06:40 AM Thread Starter
Angry E4OD probems, can't find anything similar searching, HELP.PLEASE!
I own a small repair company and this truck is one of my favorites, my friends think I nuts, but I just cant give up on her. Being an industrial mechanic this thing is driving me crazy. I hate being just a parts swapper.
96 OBS, 4x4, dually, heavy welding service body, sits about 8000 lbs. 180K
I have been having trouble with the tranny on it since I bought it. I have tried the usual suspects in everything I have read so far. It seems like the TC is coming unlocked and then it starts banging shifts hard. It happens totally erratically. I have found that if I stop and shut the truck off or sometimes just out in park and back in drive, it will shift fine.
-happens in city or highway driving
-when it happens RPMS increase to hold the same speed and I can move the revs all around with the throttle.
-Sometimes shifter light blinks, sometimes not
-Shifts so hard the truck bangs.
-Might go a week , might go a mile
-Standing on the brake with it to the wood, the it revs to about 2K.
-Had local shop put a good used rear end, now it seems to happen more frequently now.
-speedo moves a little, 2-3 mph going 60 MPH. It think this is from when the speedo got the snot beat out of it when my VSS failed and I had to drive it home.
What I done so far;
All OEM parts, no aftermarket
-New shifter position switch and pigtail. Properly adjusted the neutral position switch. Old one was kinda corroded.
-New shifter cable when I replaced the switch.
-new VSS
-Third brake light seems Taillights seem OK.
-Fluid change, just as maintenance, old fluid was still red and smelled fine.
My gut tells my electrical, but maybe that's just wish full thinking.
Where should I go from here?
Thanks for your help.
jjdude is offline
post #2 of 2 Old 10-20-2013, 01:14 PM
sgt dave's Avatar
Quoted: 3 Post(s)
o/d light blinking means there is a trouble code. you should have it scanned before you go any further.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
