E4od please help I am at a loss! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-13-2013, 06:11 PM Thread Starter
Ok guys I have had my truck since may and having issues with tranny since I got it. Any help and input would be GREATLYappreciated!
Purchased truck in may and was told tranny was rebuilt with 3k miles. It says had a hard shift from first to second. It sometimes also seems very sluggish she. First accelerating. I took the truck on two trips that were over a two hour drive. Both times the o/d light began blinking but shut off a day or two later after I was home and driving like I normally would. My speedometer bounces around a little bit on the highway as well. Where do I start? What might be the problem? Like I said any input is greatly appreciated. Thanks!
Nick97Powerstroke is offline
post #2 of 4 Old 10-13-2013, 06:24 PM
ZMANN's Avatar
Quoted: 1570 Post(s)
the blinking OD light meant you could have pulled some codes
with a decent code reader ( better than autozone )
or even some tranny shops will read them
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 10-13-2013, 06:27 PM Thread Starter
Is it normal that it stopped blinking on its own?
post #4 of 4 Old 10-13-2013, 06:27 PM
ZMANN's Avatar
not sure where the older trucks read from but most of the fords use the VSS
sensor in the rear differential some use the output shaft IIRC ?
so the bouncing may or may not be related to a sender/sensor it ay be the gauge
We Miss you Ronnie
ZMANN is offline
