96 f350 e40d problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-24-2013, 05:25 PM Thread Starter
So this problem started after I drove in alittle mud. it accelerates fine but when getting up to 35-45mph and shifting into 4th gear its all good but when slowing down is where the problems start. So letting of the throttle the truck stays around 900-1000 rpm then while braking it revs up to around 1200-1500 rpm. It also jumps and bucks and the brakes lock up sometimes while braking to a stop and today for the first time it stalled out while coming to a stop. The tranny does have a shift kit and a deep pan on it and the truck has 213k miles on it but i do not know how many miles with the shift kit. I need y'alls help so i can get this problem fixed. I will take any advice and check anything at this point.
c1wenzel is offline
post #2 of 3 Old 09-24-2013, 09:01 PM
Quoted: 48 Post(s)
How much is "alittle" mud? How deep?
Did you check the brake lights?
madpogue is offline
post #3 of 3 Old 09-26-2013, 03:49 PM Thread Starter
It wasn't that deep maybe center of the rim and yes all brake lights are working. After talking some buddy's of mine i think the valve that should open to down shift from 4th gear is stuck closed. But I don,t know how to fix it.
c1wenzel is offline
