Transmission Oil - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-10-2013, 09:01 AM Thread Starter
smokey73's Avatar
Transmission Oil
What is the general consensus on what type of automatic transmission oil or additives to run. I've got a '97 4X4 w/200k. I only put about 10k miles a year on it, most of which are pulling something. I'm opposed to synthetic oils in general, I don't think that they would be worth it.
'97 F-350 SW 4x4 XLT CCLB
smokey73 is offline
post #2 of 3 Old 08-28-2013, 05:37 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Basically the electronic trannies need the thinner synthetic to work with small ports and the electric solenoids.
dirtcrew51m is offline
post #3 of 3 Old 08-29-2013, 02:13 PM
Chop's Avatar
I too have been opposed to synthetic for many reasons including the costs but dealing with expensive transmissions that get severe service and heat I chose Mobil One on my last service .
I was pleasantly surprised by the shifts hot or cold ,which makes me a believer in synthetic for this application . I did add a Trucool cooler ,replacement pan from Ford with drain ,filter , and drained the convertor as well .
Mobil One can be had anywhere for less than 10 bucks a quart( I know that's high ) or Amzoil can be a bit less if you know a dealer .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
