E4OD Overdrive light flashing/No speedo - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-09-2013, 09:40 PM Thread Starter
Hey guys today I just had a problem start with my tranny in my 96 F350 4x4. I drove the truck for about 10 minutes pulled into the local auto parts store, when I left I backed out put it into drive started going down the road and the truck wouldnt shift just reved up to about 2200-2500 rpm, was stopped in a construction zone looked down and the Overdrive light was flashing.
When the truck wouldnt shift I noticed the speedo was at 0kmh did a bit of research and that means it could be a speedo sensor? Before today my speedo would jump around but the tranny never acted up, does the speedo bounching before this futher prove its a speedo sensor causing this issue. The overdrive light flashed in a buddys truck and it was the torque converter.
I checked the tranny fluid it wasnt low and didnt smell burnt, any ideas guys? thanks
96CCstroker is offline
post #2 of 5 Old 07-09-2013, 09:43 PM
ZMANN's Avatar
Quoted: 1901 Post(s)
u can pull the vss in the rear diff and try to clean it
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 5 Old 08-02-2013, 07:39 PM
Vss is bad, bad connection, also the 3rd brake light is asocitated with that circuit and can also cause problems if the light is burnt out.
born2ride14 is offline
post #4 of 5 Old 08-02-2013, 07:54 PM
Quoted: 58 Post(s)
Does the odometer still display a number? If so, does it count up as you drive?
madpogue is offline
post #5 of 5 Old 08-03-2013, 08:00 PM
fr9090's Avatar
Quoted: 4 Post(s)
Running lights still work? Dash lights? Mine was a blown fuse under hood. Big main 50 or 60. I think it was fuse 21
fr9090 is offline
