Remote Tranny Filter - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-26-2013, 04:59 PM Thread Starter
I have a Derale external transmission filter kit, should i install it as a bypass or as a direct flow filter?
there were no instructions with the package...
cheers!
Luke
MetalKrook is offline
post #2 of 2 Old 06-26-2013, 08:53 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
I have a Dieselsite remote filter kit on mine. It is basically full flow, but it will bypass if the filter starts getting restrictive. I don't know anything about the Derale stuff, and I would probably do some good research on it prior to installing it in a full flow configuration. Cheers!
Patrick Feeley is offline
