Need tips on changing Torque converter - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Ozonkiller
post #1 of 5 Old 06-25-2013, 06:03 PM Thread Starter
Are there any tips or tricks I should know about in changing the converter in my '96 F250 2wd.
I changed the oil and filter and everything looked great so the trans itself seems to be healthy. The lock up is slipping a bit and throwing a code (Original converter with 202,000 miles)
Anyway, while I was under there it all looked pretty straight forward but you guys always seem to have a trick up your sleeve.
Thanks,
Tom
Dickey likes this.
Ozonkiller is offline
post #2 of 5 Old 06-25-2013, 11:46 PM
JSchuricht's Avatar
There's not much to it. Unbolt the flexplate from the TC, slide the trans back then slide the TC off. Turn the new TC while sliding it on the input and make sure it seats all the way. I would use the cheepest TC I could find, with 202k, the rest of the trans probably won't last long.
JSchuricht is offline
post #3 of 5 Old 06-26-2013, 03:32 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Thanks,
Tom
Unbolt converter from flex plate, slide trans out, remove old converter, fill new converter with fluid, install new converter on trans... Before re-installing trans here is a little trick i learned after doing a bunch by myself, using one of the inspection cover bolts fasten a 10mm wrench in a position where is holds the converter in place. This will prevent it from sliding off the input shaft when your installing.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #4 of 5 Old 06-26-2013, 03:53 AM
replace the input seal on the trans and put a coating of tyranny fluid on it
DieselFord is offline
post #5 of 5 Old 06-26-2013, 08:23 AM Thread Starter
Yeah, I planned on the new seal. What do I need for the dipstick?
That's a great idea for holding the converter in place.
Thanks guys,
Tom
