95 e4od headache - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-16-2013, 05:40 PM Thread Starter
Tivs's Avatar
95 e4od headache
95 4x4 269k miles doesn't leak fluid is good. Never changed the trans filter though. Anywho i start the truck let it warm up and when i shift it wont engage unless i give it some gas. Another thing is i live on a hill and when i **** from reverse to drive i have to keep my foot on the brake and accelerate or the truck will roll. When i come to a stop light the truck jerks forward or hops and drops idle like the tq converter is locking and unlocking. Most of this goes away after 30 miles of drivin. ...but it does sometimes do the not eengaging thing and roll on me when its warm to. Trans doesn't seem to slip when im driving, if. Wot its pretty good about giving me the power if the od is off but when its on it shifts early. Any ideas
SOLD: 99.5 F-250 ECLB, Zoodad mod, aih delete, 22k mod, wix 46637,16.5s wrapped with 35x12.50 BFG T/As s, ccv mod, 140v IDM, heater core ball valve mod, 324,000 miles
95 F-250 ECLB, E4OD, 3in turbo back straight piped, diy intake w/ 6637 and riffraff prefilter, cool go fast stickers, 140v idm, need new ball joints and king pins...negative camber is out of this world. 266k miles
Tivs is offline
post #2 of 5 Old 06-16-2013, 05:42 PM Thread Starter
Tivs's Avatar
Sorry for the wording and sloppyness, my phone blows
Tivs is offline
post #3 of 5 Old 06-17-2013, 02:24 PM Thread Starter
Tivs's Avatar
Well ive known my icp is bad so i figured id unplug it and see if it did anything. ....holy night and day shifting wise. Engaged right away and i didn't have to hit the accelerator to move...it moved on its own. Does this sound like the problem? Bad icp
Tivs is offline
post #4 of 5 Old 06-21-2013, 02:51 PM
nra1ifer's Avatar
"Never changed the trans filter though."........
Without any more detail of preventive maintenance (or lack thereof), I would suggest that you do the complete drain (including the torque converter), REPLACE THE FILTER, add a magnefine filter to the return line coming from the radiator/cooler, and add a drain plug to the transmission pan while you're at it. Then see if the transmission works like it's supposed to, or not.
I hope you are keeping up with other PM items.
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
nra1ifer is offline
post #5 of 5 Old 06-26-2013, 05:13 PM Thread Starter
Tivs's Avatar
Im sure my problem is my icp bbecause its unplugged and is shifting amazing
Tivs is offline
