Very harsh low speed downshifts...... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-08-2013, 07:52 PM Thread Starter
579
579's Avatar
I've been researching my problem quite a bit sourcing most of my info from this site. Searches, reading, searches, and more searches and reading.
I have narrowed it down...... Bold statement for someone who has owned his diesel for less than a month
The vss
The EBPS tube is completely clogged-- a new one is on the way ..
And the tps and throttle bracket sensor mod that's floating around. I have not bent the tab on the pedal assembly nor have I made the other sensor adjustable by drilling out the holes.
At 25mph the rpms are at (+) (-) 600. And the truck is definitely not coasting ---it is down shifting prematurely .....
All other shifting and engine operation seems fine.
Please, any feedback would make my weekend. Thank you.
579 is offline
post #2 of 7 Old 06-11-2013, 07:52 PM Thread Starter
579
579's Avatar
C'mon y'all..... I see some of you have viewed this post.
If you dont give me some input ill have to assume I have a super rare engine brake option offered from ford ! Lol !
579 is offline
post #3 of 7 Old 06-11-2013, 07:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Valve body
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 06-11-2013, 07:57 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Originally Posted by 579 View Post
The vss
Try these and check back! these are what i can think of?
2000-7.3L is offline
post #5 of 7 Old 06-12-2013, 06:58 AM
Where is this EBPS tube? I need to check mine.
Thanks
96 F250 CCSB 4wd 7.3
77 FJ55
90 Isuzu Trooper
onemanarmy is offline
post #6 of 7 Old 06-12-2013, 08:30 AM Thread Starter
579
579's Avatar
directly in front and on top of the engine. there is a little wire harness going to a sensor. below the sensor is the tube. then it runs down the block on the passenger side to the passenger exahust manifold.
look up the precise instructions to remove it. do a search on here. someone did a great write up on it.
and thanks yall. Im in the process of eleminating the vss and the EBPS tube as the culprits.
579 is offline
post #7 of 7 Old 06-14-2013, 05:56 PM Thread Starter
579
579's Avatar
I got the tube back on. Still no change in my shifting
579 is offline
