slave cylinder problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-05-2013, 04:41 PM Thread Starter
kkbodyshop's Avatar
truck has 217k miles an is a 5speed. 4 months ago the slave cylinder busted so i replaced it with a new one. 1 month ago i did the solid flywheel conversion kit on it an 2day the slave cylinder busted again. its cracking at the base of the nipple where the hose goes in. i did not put the lil heat sheild on it the first time i replaced it but i did 2day. im i doing sumthing wrong or is there a better one that fixes this problem. its a luke solid flywheel an clutch kit an the slave cylinder is from oreillys auto parts?
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
kkbodyshop is offline
post #2 of 5 Old 06-05-2013, 06:09 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
I'm assuming this is not the truck in your signature (since they did not have DMFWs)? I had a lot of experience with my 94 cracking slaves in the same spot (three of them I recall). The early masters/slaves had a smaller bore and they eventually changed to a larger bore system. Once I changed to that I did not have further problems. The two cylinders must match sizes. If you have to, you might try replacing the master/slave/line with a pre-bled system (the early and late masters have different orientations of the line coming out of them, so the masters and lines are different between the 2 systems). Cheers!
Patrick Feeley is offline
post #3 of 5 Old 06-05-2013, 08:07 PM Thread Starter
kkbodyshop's Avatar
yea i seen where they made a new improved one. so i need to change to it along with the clutch master cylinder?
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
post #4 of 5 Old 06-07-2013, 10:43 AM
Quoted: 15 Post(s)
If you know you still have the old-style, I would change all of it (that was the only thing that worked on my 94). Cheers!
post #5 of 5 Old 06-11-2013, 05:42 PM Thread Starter
kkbodyshop's Avatar
thanks. i ordered the complete kit master cylinder line an slave prebleed works great.
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
