Clutch fork measurement. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-30-2013, 06:58 PM Thread Starter
Can anyone tell me how much space should be between the clutch fork and the flat surface that the slave cylinder mounts to? I measured 2 5/8 inches with the slave removed and the fork held twords the rear. I'm trying to figure out if the fingers on my pressure plate are out too far. I'm having trouble with the clutch engaging the last possible inch of pedal travel and I can see that the disc is still good.
1996 f250 diesel 4x4
5 speed
luk clutch
Diy filter
4"mbrp turbo back
T.W. 6 pos chip
isspro gauges
Brawnyrebel is offline
post #2 of 4 Old 05-30-2013, 07:41 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Measure the slave rod travel with the pedal fully depressed. Minimum spec is 11mm. If you don't get enough travel, check all the bushings for the pedal under the dash: the pedal linkage to master cylinder rod, and the brake/clutch pedal box mainshaft bushings. Cheers!
Patrick Feeley is offline
post #3 of 4 Old 05-31-2013, 03:32 PM Thread Starter
It seems like i have plenty of travel at the fork. Im thinking the pressure plate fingers are pointing towards the transmission too much and allowing the throwout bearing to engauge before it should thus engauging and disengauging with the pedal almost all the way out. I was able to get my phone in the bell housing and snap a pic of the fingers and one of the disc.
5 speed
luk clutch
Diy filter
4"mbrp turbo back
T.W. 6 pos chip
isspro gauges
post #4 of 4 Old 07-12-2013, 04:27 PM
Well it is look seems like good for me . I would suggest that you should be see the things that it will make it all correct. See the bushes, and plates.
Brady1121 is offline
