Hard to get in gear. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-30-2013, 01:57 PM Thread Starter
WVaMatt's Avatar
Having trouble getting my 5 speed into gear. When the engine is off, I can run through the gears with ease. Turn the engine on, and it takes everything I have to shift into 1-5, and I can't muscle it into R.
I replaced the slave cylinder because it seemed to have a small leak, but still have the same problem. Now I'm looking at the heim joint, which from what I've read on here seems to often cause difficulty in shifting. I posted a video of what appears to be a worn out bushing. Does this look worn out to you? Could this be the source of my problem?
Here's the video: http://youtu.be/NZCO5IzXrM0
1997 Ford F250 Super Duty PSD
7.3L DIT PowerStroke Diesel
WVaMatt is offline
post #2 of 5 Old 05-30-2013, 03:40 PM
Sam Burton's Avatar
looks wore out to me, replace the bushing or get a heim, cheap fix and it definatly won't hurt
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 5 Old 05-30-2013, 05:51 PM Thread Starter
WVaMatt's Avatar
Well I replaced the bushing in the clutch pedal, and the problem remains. I also re-bled the slave cylinder, and it's still nearly impossible to shift gears. When I have the clutch pressed down and I'm trying to shift into gear, the truck actually creeps forward. I can start the truck in gear, and in 2nd with the clutch to the floor, the truck creeps forward. It seems to me like the clutch isn't fully disengaged. Any ideas?
WVaMatt is offline
post #4 of 5 Old 05-30-2013, 06:41 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Measure the slave rod travel with the pedal fully depressed. Minimum spec is 11mm. If you don't get enough travel, check all the bushings for the pedal under the dash: the pedal linkage to master cylinder rod, and the brake/clutch pedal box mainshaft bushings. Cheers!
Patrick Feeley is offline
post #5 of 5 Old 05-31-2013, 05:43 AM
Sam Burton's Avatar
could be the clutch master cyl.
1978 Ford Bronco
12v Cummins
Powerstroke E4OD
