E40D trouble brewing - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-20-2013, 06:19 AM Thread Starter
1996 F250 4wd 7.3 w/E4OD
190K miles
Had this truck a month, seems to have been taken well care of, but I have no maintenance history
I have put less than 1000 miles on it in the past month
3 times after driving a mix of highway and city, the trans will act up. Most of the time I'll be driving at highway speeds and the TC will unlock and revs will increase (1500 to 1800 rpm), will do this a few times, and then 'catch' and stay in 4th. Will do this on cruise control as well as just driving around.
Once, it went beserk. I was on the highway, came to a stop, went to give it throttle and the revs just went up and barely moved. After revving for a few seconds, it 'caught' and tried to get going. The revs were very erratic and the trans was searching for the right gear. I got a flashing OD light then. Came to a stop, cut the truck off and let it cool. Cranked back up and had no issues. No OD light for 3 weeks now. Have not had the codes read.
Three days ago it did the same thing, but I got no OD light. Pulled over, put in park, put back in drive and went on my way. Drove 200 miles yesterday and no problem, except once it 'stumbled' when going from 3rd to 4th.
Now, this seems like some sort of electrical problem, but I'm no trans expert. I beleive most everything in the trans is a mechanical part that is controlled by a variety of external sensors and controllers, correct?
The truck works great otherwise, no CEL, no wierd shifts, plenty of power. Speedo and tach work fine.
Other than getting the codes read, which I will do, what should I be on the lookout for? When the mechanic tells me what he thinks is wrong, I want to be educated on the subject. I want to catch this before it craps the bed in the middle of no where.
Thanks
96 F250 CCSB 4wd 7.3
77 FJ55
90 Isuzu Trooper
onemanarmy is offline
post #2 of 8 Old 05-20-2013, 07:11 AM
clatterindiesel's Avatar
Check all bulbs. Including 3rd brake light on cab. Then report back, if any are blown replace them.
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
post #3 of 8 Old 05-20-2013, 08:14 AM Thread Starter
Thanks..
No tunes, no mods
all bulbs are good, checked them. Replaced third brake light before I had any problems. Brake lights and license plate lights function properly.
77 FJ55
90 Isuzu Trooper
post #4 of 8 Old 08-16-2013, 11:27 AM
Rockdog97's Avatar
If there is no third brake light bulb in the socket, would that make any difference?
My truck does the same thing sometimes.. It will also "rev" just a bit when I put on the right blinker (to change lanes) then when I turn the turn indicator off, it surges just a bit..
Randy Wheeler
1997 F350 4x4 Crew Cab PSD LB
Rockdog97 is offline
post #5 of 8 Old 08-16-2013, 11:37 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
I'm fairly certain there needs to be a bulb in there. Cheers!
Patrick Feeley is offline
post #6 of 8 Old 08-23-2013, 12:29 PM
Rockdog97's Avatar
Mine did the same thing and it turned out to be a faulty Manual Lever Position Sensor (MLPS) (or also known as Transmission Range Sensor).
I had a new MLPS installed yesterday and so far, she shifts great and also seemed to have cured the right-turn signal indicator lag issue I was having.
Randy Wheeler
post #7 of 8 Old 08-23-2013, 12:57 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Please elaborate on the turn signal lag your talking about, i think i have the same thing, and my trans too is acting a bit strange(nothing crazy...yet)
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #8 of 8 Old 09-02-2013, 12:42 PM
Rockdog97's Avatar
Well it seems that the new MLP sensor did not fix the turn signal problem.
This is what it does: if I'm driving down the freeway and put my right turn signal on all the way (so it stays on w/o holding it) and then I turn the turn signal off (flick the lever down to the middle position).. right after I turn it off I get a little "surge" as if I just hit a sheet of ice (revs go up a bit) but then settles down and all is normal... If I hold the turn signal just so the blinker is on (but not dont engage the turn signal lever all the way into the "lock" position), it wont surge... so somehow I think there is a fault or something in the shift column on the steering column making it do this, but I"ve not been able to figure it out.
Hope that helps...
Randy Wheeler
