oil pan sludge - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-23-2006, 09:47 AM Thread Starter
smokin n strokin
oil pan sludge
im noticing a black sludge build up on the back side of my oil pan below the trannyon my newly bought 95 psd it only has 86 k original miles is this common leakage!!!
adam95 is offline
post #2 of 4 Old 09-23-2006, 11:15 AM
7.3 tech, supporter
fordnut85's Avatar
First of all no leakage is common, you have ones that you know where it's coming from and ones you don't . If there is anything leaking in the valley of the motor it will run down to the back of the motor and down the bellhousing. So start by cleaning the motor really good and see if you can trace the leak back to it's source and we can go from there
BTW, welcome to the site man, you will find alot of great info and people here!!!
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #3 of 4 Old 09-23-2006, 11:34 AM
The Fat Mod
Logan's Avatar
Logan is offline
post #4 of 4 Old 09-23-2006, 11:53 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Welcome to Powerstroke.org!!!
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
