Clutch questions
I have a 96 powerstroke with a 5 spd and I am going to replace the clutch on here in the next week or two. I have heard alot about the dual friction flywheel, but I dont really understand it in comparison the a standard fly wheel. I would like some help find the right replacement kit so I will do this job right. I have found many kits on the market and I am wondering what some of the members think about Haynes and Centerforce, and Zoom. Anyone with any information please drop a line. Nick
I replaced the dual mass clutch on my '95PSD with a Luk kit.
The Luk kit seems fine, less vibration than the dual mass. BUT I found out after the fact that Luk makes two diff clutch's for the PSD a std and heavy duty, and I would recommend the HD, just because I don't think it's that much more. I bought my kit on a Saturday (truck was torn down at this point and i needed it fixed asap) from a guy I thought was helping me out at a local tranny shop and paid almost $900 for it, which after visitng the dealer a few minutes before that and getting hit with a $1500 figure, seemed like a great deal. Only to find out it wasn't the best Luk clutch and I paid $300 more than I could have bought it online for.
I have a 97 psd and i want to replace the clutch also i mean when i turn the truck off it shackes rattles and rolls sounds like the engine is going to fall out!! is a clutch job somehting you could do in your driveway or what?
And I was getting a lot of vibration before I replaced the dual crap clutch. |
Here is a trick for yall, pull 1 of the bell housing bolts out and go to the local hardware store and get a bolt with the same thread diameter and pitch only about 10" long. Remove 2 of the bell housing bolts on either side of the tranny and insert the 2 long bolts. Then when you unbolt the tranny you can just slide it back on the 2 long bolts. When your done just slide it forward on the bolts and it aligns itself!!
I would look at South Bend Clutches. Lil pricer than some of the others but they are very tough clutches and ya can't beat the customer support from them either.
i have a 97 5 speed would i be bale to replace that witha new 6 speed or upgrade it?
'95? I'd like to get some more highway speed out of her. Rt now to run 65 it's making about 5lbs of boost. It'd be nice to run 65-70 w/o boost as that would save fuel, less heat in the eng, etc |
They will bend for sure but you have to support the weight of the tranny with a jack, the bolts are just for alignment. I have bone EVERY clutch job using this method and it works great
