97 F350 with E4OD - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2013, 04:49 PM Thread Starter
97 F350 with E4OD
Looking to buy a 97 F350 but the owner says it has to be started in natural to get the trans to work? Any ideas?
"Truck must be started in neutral to shift properly into other gears - needs some repair on the shifter."
ziegler is offline
post #2 of 4 Old 05-03-2013, 05:06 PM
JD3020's Avatar
Its the transmission range sensor on the driver side of the transmission, the shifter linkage goes through it. Its either shot, or just needs aligned slightly. It tells the PCM what gear the truck is in. Very simple/easy fix, and isn't that expensive at all.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #3 of 4 Old 05-04-2013, 01:55 PM Thread Starter
Got some more info, transmission works fine, the problem is the safety mechanism that tells the shifter your foot is on the brake? Also the brake lights do not work because the fuse is blow and keeps on blowing. Is the fuse the fix to the shift problem?
ziegler is offline
post #4 of 4 Old 05-07-2013, 04:33 AM
Sounds like a faulty brake light switch?
96 F250 CCSB 4wd 7.3
77 FJ55
90 Isuzu Trooper
onemanarmy is offline
Tags
e4od
