Clutch trans issues - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-23-2013, 05:48 AM Thread Starter
Clutch trans issues
I'm starting to have issues w my zf5 and clutch in my 96 7.3 w 230000 miles
I push in the clutch and it shutters and is getting harder and harder to shift into gear and even grinds sometimes
I'm thinking a new clutch should I do anything to the tranny while the truck is down
nvrstsfd23 is offline
post #2 of 5 Old 04-23-2013, 06:40 AM Thread Starter
If I decided to rebuild the zf5 where is the best place to get a kit and what all parts should I replace
post #3 of 5 Old 04-23-2013, 10:12 AM
Quoted: 48 Post(s)
Have you checked the hydraulics and the pedal/pushrod linkage?
madpogue is offline
post #4 of 5 Old 04-23-2013, 10:30 AM Thread Starter
What should I check on the hydraulics the linkage is ok
post #5 of 5 Old 04-23-2013, 11:50 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
How much slave cylinder travel do you get? Cheers!
Patrick Feeley is offline
