transmission gone?? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-21-2013, 04:00 PM Thread Starter
transmission gone??
i have a 95 with the e40d. i turned off highway onto my neighborhood street started to give it fuel when it acted like a boat motor/prop coming out of the water.it reved but didnt go anywhere then it caught and started driving again,but repeated this 2-3 times, and cut off as i coasted to my driveway. it wouldnt start. i had to pull it in the yard. now it wont start, and soundslike starter is dragging or in a bind. does anyone have any ideas?
rollinblacksmoke is offline
post #2 of 7 Old 04-22-2013, 01:32 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Have you checked for codes? OD light flashing?
CT Performance, Inc. is offline
post #3 of 7 Old 04-22-2013, 05:16 PM Thread Starter
thanks for the reply. may be able to get a scanner by the weekend, no flashing o/d light.if i get the scanner, will it give me any codes if i cant start it?
post #4 of 7 Old 04-23-2013, 04:12 PM Thread Starter
newest wrinkle. i had a few minutes, and an available son for a few minutes today. i had him attempt to start the truck while i watched under the hood....NOT GOOD!!!!!! as the starter tried and turned over, the crank nor any other pulley was turning!!!!! will try to get inspection cover off transmission this weekend as well. any ideas??????
post #5 of 7 Old 04-24-2013, 10:40 AM
Quoted: 43 Post(s)
Can you turn the engine by hand?
Did you hear a click from either the starter relay on the fender or the solenoid down on the starter?
madpogue is offline
post #6 of 7 Old 04-24-2013, 05:40 PM Thread Starter
dont know about spinning it yet. will try to put a ratchet on crank bolt this weekend along with hooking up a scanner. the relay did click and starter was turning S L O W L Y. just dont know what it was turning. will also find out this weekend when i pull the transmission inspection cover off.
post #7 of 7 Old 04-27-2013, 01:42 PM Thread Starter
it is the flexplate......center broke out of it!!!!!! engine spins by hand, had inspection cover off and watched. also had checked fluids in engine and tranny prior to pulling insp. cover off, both looked fine. i feel A LOT BETTER, but now, is it possible to drop tranny and transfer case on the ground and replace it myself??? or do i need to send it to a shop????
