Shifting Question - Ford Powerstroke Diesel Forum
Old 09-15-2006, 08:23 PM
Shifting Question
Got a 96 F250 crewcab 4x4 PSD manual trans. It's hard to get shifter into gears. Is it a clutch or shifter problem?
Old 09-15-2006, 08:30 PM
what gears?? does it grind or does it just not want to go in?? if you pump the pedal does it help?? at a stop, does it go into reverse easily??
Old 09-15-2006, 09:06 PM
It is hard to go into all gears at a stop.
Old 09-15-2006, 09:16 PM
sounds like a hydrolic problem...slave/master to be exact. Its always a possibility that the pressure plate is getting weak....but the symptems point to the hydrolics...
Old 09-16-2006, 10:36 AM
7.3 tech, supporter
Double check the bushing where the clutch pedal attaches to the linkage, it could cause the same issues. It will also feel like the clutch enguages as soon as the pedal comes off the floor
Old 09-17-2006, 08:06 AM
Send a message via AIM to SuicideAxles Send a message via Yahoo to SuicideAxles
Had the same thing happen to my '96 a few weeks ago. Like FordNut85 said, check the bushing on the clutch pedal to master cylinder pushrod first. Could be a simple $.59 fix. If it's intact with no play, run down to your nearest auto parts store and pick up a new clutch slave cylinder & master cylinder for your truck. I spent $99 for both at O'Reilly Auto Parts. Easy to install with only 1 wrench, 2 bolts, 1 electrical connection, and a spring clamp for the slave cylinder. Follow the directions in the boxes & it's simple...took about 30 minutes to install & bleed the slave & master. Works like a charm!
