97 7.3 L f250 SD with automatic should I worry? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-26-2013, 08:29 AM Thread Starter
I acquired my dad's 1997 f250 SD 7.3 L 4x4 with auto. Only has 58,000 and he bought it new. This summer I am going to pull my 26 foot camp trailer and I have heard the weak link is the automatic tranny. Anything I should do to the trannny to prevent any problems in the future? By the way this is a great website!!
idaho211 is offline
post #2 of 19 Old 03-26-2013, 08:30 AM
gabegoforth's Avatar
Thats a Dodge thing.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #3 of 19 Old 03-27-2013, 11:04 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
It's not just a Dodge thing. The E4OD's can be a problem too. You might want to do a fluid change (unless you know when it was done before) and I would probably replace the factory tranny cooler with a larger unit like the 6.0L factory cooler or a TruCool Max. Other options might be a TransGo Tugger kit or a Valvebody from Brian's Truck Shop (BTS) or John Wood Automotive. Cheers!
Patrick Feeley is offline
post #4 of 19 Old 03-27-2013, 03:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Also get a gauge for the trans, I will bring it to an idle north of 210 to hopfully save it, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 19 Old 03-27-2013, 07:24 PM Thread Starter
Yeah the consensus I got from a different thread was change the fluid, filter, and a larger tranny cooler. I will look into those brands of coolers. Thanks
idaho211 is offline
post #6 of 19 Old 03-27-2013, 08:47 PM
Dude, mine was supposedly replaced at like 170-180k miles. your good for a long time, but I totally. second the gauge and a bigger cooler would probable be nice. I have multiple dodges and they are like 100k general maintenance. I would in fact almost bet mine was done at 210k because the tranny pan bolts are still really shiny.
post #7 of 19 Old 04-14-2013, 09:44 AM
greygearhead's Avatar
When I had my 97 I added a Hughes +4 qt pan, a Banks trans-comand shift controller and a Ford trans cooler from a 2001 diesel. I also ran Mobil 1 syn trans fluid; 20 qts with the new pan. Also, drain the torque converter! The 97 E4OD was the last trans to allow you to drain it.
greygearhead is offline
post #8 of 19 Old 04-14-2013, 02:19 PM
clatterindiesel's Avatar
Id put the truck in my house on display! 58k miles! Zoweeee!
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
post #9 of 19 Old 04-17-2013, 12:25 PM
StrokinNSmokin6.0's Avatar
My trans made it to 220k before needing a rebuild.
04 F350 With all the mods.
StrokinNSmokin6.0 is offline
post #10 of 19 Old 04-19-2013, 04:43 AM
KS_
Quoted: 22 Post(s)
Mine made it 500k miles before a rebuild, it'll be fine as long as you don't put it on cruise control going up mountains. My dad has told me stories about that... morons
KS_ is offline
