ZF5 Rebuild - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-07-2013, 06:12 PM Thread Starter
ZF5 Rebuild
Hey guys, I'm a space cadet and posted my thread in the wrong section. I was thinking I didn't have very much activity on it. Whatever, here it is.
Transmission removal and rebuild ZF5
Still trying to figure out were to get shims for the preload without having to buy an entire kit for 100$+, when I only need two or so shims on one size.
1997 F250 7.3 5 speed, 3.55s, D60, 4" Diamond Eye Exhaust, Napa Intake Filter, E-Fuel, 35" bfg mt's, stage 2 rosewoods/tuning, Gauges
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
--Henry Ford
csdwarf11 is offline
post #2 of 12 Old 03-07-2013, 08:06 PM Thread Starter
Also looking for a new throwout bearing while the tranny is out. Its not bad, but it isn't the best and I mise well throw a new one in. I have a SMF, so were do I go about getting a new throwout?
thanks guys!
--Henry Ford
post #3 of 12 Old 03-07-2013, 08:18 PM Thread Starter
Done researching for the night, Im just trying to find everything I need so I dont have to take the transmission back out.
I'm reading something about an upgraded shift fork? I can't seem to find much on it....
--Henry Ford
post #4 of 12 Old 03-08-2013, 04:20 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Here are some part numbers:
Clutch, Release Lever
(Ford) E7TZ-7515-A
Clutch, Throwout Bearing
(Ford) F1TZ-7548-A
Cheers!
Patrick Feeley is offline
post #5 of 12 Old 03-08-2013, 06:46 AM Thread Starter
Awesome! I assume thats the updated lever? Ford wouldn't continue making a bad part would they?
thanks again!
--Henry Ford
post #6 of 12 Old 03-08-2013, 07:15 AM
Quoted: 13 Post(s)
I remember the release lever being more of a problem on the SD's than the OBS trucks. I'll look for a TSB on it, but that's the part I used on my 94. It was worth the $20 just to replace it when I put the new tranny in. Cheers!
post #7 of 12 Old 03-08-2013, 08:07 AM Thread Starter
You are probably right, I have been having a terrible time finding information about the "defective lever" Maybe thats because it doesn't exist haha.
I couldn't agree more with it being worth 20$ considering the work involved to drop the tranny. I did do it in about 2 hours though, took my time. First time ever working on a zf5 here o.O
--Henry Ford
post #8 of 12 Old 03-08-2013, 03:52 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
You can change the fork with the trans in the truck
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #9 of 12 Old 03-08-2013, 07:37 PM Thread Starter
Oh, awesome. I might not bother change it right now them. Appreciate it.
Didn't get much done on the transmission today, was over at the shop this morning getting ready and my sister pulled in. She needed a new rocker on her car for inspection. Spend a good part of the day on that, finishing it up tomorrow morning. Then I can put my attention back into the transmission, ill grab some pictured too.
--Henry Ford
post #10 of 12 Old 03-09-2013, 01:42 PM Thread Starter
Anyhow. Just finished my sister car a while ago, started back on my project. Got the shaft about apart, I was having a 4th gear pop out problem and I have yet to find anything out of the ordinary until now.
The last year on the tranfercase side of the main shaft has about 3/32" of walk back and forth. No other gears were lose like this, and when you fiddle with the play of the gear, it will pop out.
Very hard to explain, but I guess im trying to say I found something that might have been my 4th gear pop out? I'm going to go pull it off right now, then I have 2 gears left after that. Then the main shaft is completely broken down.
Bummer* Bought MTL, not supposed to use it with new syncros? lol.....they do a good job advertising it "Perfect friction coeficient for sycronizers" jerks...
--Henry Ford
