transmission slipping bad - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-28-2013, 06:20 AM Thread Starter
I had my truck (95) worked on to fix a leaking front main. The mechanic washed the engine bay to clean out the oil. Now the transmission is slipping real bad, and the speedo is fluctuating.
I thougtht I read somewhere that there was a sensor or something that can go bad and cause these problems.
bogof is offline
post #2 of 2 Old 02-28-2013, 07:30 AM Thread Starter
so after a little more research it sounds like the mlps. does that sound like the symptoms of water in there?
bogof is offline
