solid flywheel conversion? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-06-2013, 04:39 PM Thread Starter
Has anyone converted there flywheel from the stock dual mass to a solid flywheel. I have heard great things about the conversion but also heard some horror stories. whats your imput on it?
oldschooldiesel is offline
post #2 of 7 Old 02-06-2013, 05:35 PM
Quoted: 53 Post(s)
Running SMF on both our trucks; best money I've ever spent on both. One truck was a ticking time bomb on the DMF; you could move the clutch cover about 2-3 inches relative to the front half of the flywheel. In both cases, first time driving it I chirped the tire a couple times, before getting the hang of the clutch action. As for the gear rollover noise, either it went away or we both just got used to it. Some folks overfill the tranny by filling it through the shifter hole to quiet the gear noise. I honestly don't know of any downside to it, and given that the alternative means you risk grenading the tranny case, it's a no-brainer to me.
madpogue is offline
post #3 of 7 Old 02-06-2013, 05:41 PM
sargar's Avatar
Re: solid flywheel conversion?
I've done one and couldn't tell a difference.....other than the fact that the truck felt smoother because the dual mass was coming apart. It was also less expensive than buying another dual mass setup.
Sent from my DROID X2 using AutoGuide.Com Free App
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #4 of 7 Old 02-06-2013, 06:46 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Did it on my 94 with a SouthBend Con-O kit. Easier pedal action, no more rattling DMFW, much cheaper than replacing the DMFW and clutch, and stronger clutch. Gear rollover noise didn't bother me since it is after all a truck (and the 94s are loud anyway). Cheers!
Patrick Feeley is offline
post #5 of 7 Old 02-16-2013, 11:56 AM
PowerstrokinIt F250's Avatar
just did it on mine. after you fill the tranny pull the shifter out and add an extra quart to quiet it down. also would be a good time to get a new pedal pox and try the heim joint mod. youll be glad you did
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #6 of 7 Old 02-16-2013, 01:42 PM
sargar's Avatar
Hate to derail the thread but what does your tailgate say after "stroke this"?
sargar is offline
post #7 of 7 Old 03-07-2013, 06:44 PM
"Stroke this chevy boy" I think? ;p
1997 F250 7.3 5 speed, 3.55s, D60, 4" Diamond Eye Exhaust, Napa Intake Filter, E-Fuel, 35" bfg mt's, stage 2 rosewoods/tuning, Gauges
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
--Henry Ford
csdwarf11 is offline
