tranny leaking - Ford Powerstroke Diesel Forum
Old 09-26-2012, 04:23 PM
tranny leaking
'97, Auto...tranny is leaking...not at the fluid pan, but before that...place where the fluid is comin from looks like a modified V or U shaped with sharp corners. It's leaking in the middle. I know I have a rear main seal leak, but this is tranny fluid. Any ideas? Take it to my mechanic? I added 2 quarts of tranny fluid this morning and she is leaking. Not hemorrhaging, but leaking pretty good.
Old 10-07-2012, 07:37 AM
Is it comming from the front of tranny, dripping from inspection plate? Could be input shaft seal.
Old 10-09-2012, 04:53 PM
are you sure its trans fluid? and it probly isnt the rear main leaking on the rear passangerside of the valley there is a drain hole that will allow any oil or fuel from the valley area to drain from and look like its the rear main going out
