Did i use the wrong shop or what? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-12-2012, 07:31 PM Thread Starter
So i decided to have my tranny rebuilt. It worked fine except for a couple of times it would not go into reverse, i think when the fluid was hot. Also when i did a service on it there seemed to be an excessive amount of stuff on the magnet. So since i had the money and might not down the road i decided now was the time.
According to the shop my tranny was in horrible condition with chewed up gears, bad pump etc. Is this possible when it worked great except for reverse and only once in a while?
Also they have had my truck now for over a week and have put the tranny in twice and still something isnt right. In fact its worse than before as it wont engage. SO my question is is this a complicated tranny? Should a tranny shop not be able to rebuild it right the first time?
I should also point out that this shop was recommended by more than one person and i cant find anybody who has heard anything bad with them.
1996 F350 xlt Crew Cab
crewcabxlt is offline
post #2 of 10 Old 08-14-2012, 07:08 AM Thread Starter
Well it turns out that there was some spring that was binding up in the valve body. Took them a while longer that it should have but its all good now.
Cost $2400 for a rebuild, twin disk converter, tugger kit, a few hard parts etc, not bad.
Thanks for all the replies...... Oh wait there was none. Luckily there are other "powerstroke" forums with more friendly members, i dont seem to get answers from here ever. Maybe next time.
post #3 of 10 Old 08-14-2012, 05:00 PM
Diesel Freak
yngbuck19's Avatar
Glad to hear you got it resolved my tranny is still on the chopping block... I just dont know where to start with it. which hard parts are you speaking of and what brand TC did you use?
1997 F250 7.3 powerstroke SCLB HD XLT
340,000 Mi.
Blown Tranny Mod
D60 Swap
4:10's
DIY E-FUEL
PHP 6 pos.
S&B CAI w/Prefilter
EBPV Delete
3" DP
Kitty Delete
Cat Back 5"
Aeroturbine 5050XL Muffler
6" Vented Tip
S.S. HPX
17"X10" Pacers
4" Rough Country Susp. Lift
KW 17 LED CabLights
35"X12" BFG KM2's
Tint 20%
Magnum CB 104" Whip
Quad A-PillarPod
GlowShift Digital Gauges
Future mods: ??? 1.5 Sticks T500
1996 ECLB XLT SOLD
1997 ECLB HD SOLD
yngbuck19 is offline
post #4 of 10 Old 08-17-2012, 05:26 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Sometimes it takes a bit for folks to reply... Not everyone is on every day.
Good to hear you got it resolved. These transmissions are not super complicated, but there are 4 valves in the vb. The 1st one I built I had a valve problem and had the trams out like 4 times before I figured out my case was bad...
Hard parts would be the planets. Pre-97 Ford used alum planets, usually a good trams rebuilder will replace the planets with steel.
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #5 of 10 Old 08-17-2012, 10:36 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
You would think that a trans shop would know what to look for if there was a problem. I could see a general repair shop having some problems but not a speciality shop
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #6 of 10 Old 08-19-2012, 07:46 AM
Hillbilly Deluxe
Quoted: 2 Post(s)
One would think... There are also alot of tranny shops that wont work on diesel transmissions. Like.I said I had my 1st e4od rebuild in and out of the truck no less than 4 times. I was building it in my friends shop who is a master builder and has been in the transmission business for 30 years, and we still couldnt figure it out. Finally we decided to start from scratch with a completly new case. Turns out that my original got heated up enough to warp it to where the VB wasnt seating properly, I mean we are talking it being off by a few thousandths. This casued it to shift poorly from 2-3.
Seth
Stroked_NY_023
post #7 of 10 Old 08-19-2012, 10:02 AM
Quoted: 4 Post(s)
Other than the bolt pattern for the bellhousing there is no difference between the transmissions. Internals are the same
post #8 of 10 Old 08-19-2012, 10:38 AM
Hillbilly Deluxe
Quoted: 2 Post(s)
What bolt pattern?? Im missing your point here... ??? We are talking e4od right??
Seth
Stroked_NY_023
post #9 of 10 Old 08-19-2012, 05:29 PM
Trackspeeder's Avatar
Gas and diesel use different bolt patterns. Internal are somewhat the same. They share the same layout.
Most important thing before rebuilding any E4 or 4R is to check the case for damage and warpage.
Warpage can be checked with a good straight edge and feeler gauges.
This space intentionally left blank
Trackspeeder is offline
post #10 of 10 Old 08-19-2012, 06:29 PM
Hillbilly Deluxe
Quoted: 2 Post(s)
Yes I know this... 460 uses same patern though... Mine was warped... Only took tearing it down 4 times to figure it out.
Seth
Stroked_NY_023
