Tunes affecting shifts? - Ford Powerstroke Diesel Forum
Old 08-04-2012, 08:29 PM
I had my trans rebuilt about 5k miles ago, but every since i have had this truck it stutters when shifting from 2nd-3rd, depending on throttle position. It is tuned by wildman and was built up and has a shift kit. Any input would be great.
Old 08-06-2012, 09:07 AM
Bump.......
Old 08-06-2012, 11:05 AM
Feedback Score: 5 reviews
99% bet its not the tunes...who built the trans?
Old 08-06-2012, 11:59 AM
The trans shop I went with is a ford specialized shop. They have a good track record so I don't think they did anything wrong. But they could have. And one of the reasons I suspect my tuning is because went I switch to different tunes I doesn't do it. Mainly on my dd and econo. Tune.
Old 08-06-2012, 12:08 PM
My bad reread your post and its happened before the trans. Well you might want to have newer tunes reburned..TW doesn't charge for reburns..
Old 08-06-2012, 12:11 PM
That's what I was thinking of doing. I had them done once for the new trans and everything. But still a problem and when pulling a good load it hunts between 3rd-OD in heavy tow
Old 08-07-2012, 05:58 AM
Weird as I've never had a tune problem with the OBS trucks from Tony...make sure you get TDEO trans shift stragities not the TEE0-5 ones are they are weird and whats in a '95 pcm.
Old 08-07-2012, 10:19 AM
Ok I will try that. Thanks
