E4OD possibly needs rebuild have a few questions - Ford Powerstroke Diesel Forum
Old 07-29-2012, 11:57 AM
I am thinking my tranny might need a rebuild. It has an intermittent problem with reverse. Sometimes i will go to put it into reverse and it wont do anything. If i rev it up it will "slam" into reverse just for a second and then nothing again. It only does it sometimes and it might be only when the fluid is like up to about 160 or 180 degrees or so. Also im not sure if it shifts right either. Sometimes it seems like it will blow its self up before it shifts unless i let off the throttle like when i am passing a car or something.
So now for my questions;
1. Does this problem sound like something somebody recognizes?
2. Do i need a billet clutch? Single double or triple? I dont tow much maybe a car trailer at most, no 5th wheels etc.
3. What years of the A4OD will bolt right up with no modifications to my truck?
I just bought this truck and so far have already had to replace the engine as i found a crack in the block a week after i bought it ugh.
Old 08-01-2012, 12:00 PM
De-rail in 3... 2... 1...
Make sure that your PRiNDL cable is adjusted correctly before buying anything. They do stretch and bind as they age. In a parking lot where you have some space put it into reverse and see what happens. Then pull gear selector toward you and slowly up and down from the locked reverse position.
If you do a lot of towing or F-ing around then buy a multi-disk clutch TC. Otherwise the 7.3l and E4OD was used in a lot of fleet and emergency vehicles so look at getting one for a utility truck or ambulance. Buy a case of beer and bring it to a fleet shop and have them buy you the TC. Fleet parts can be a lot cheaper.
Years.... I think you can get one from a '98 diesel van all the way back to a 94 diesel truck. Before that you can get into more C6 variants of the tranny.
Old 08-01-2012, 02:09 PM
If it was an adjustment you would think that revving it up would have no effect. If i rev it up it jumps into reverse for a second.
Old 08-01-2012, 02:26 PM
True, unless the cable is "just so" out of alignment that revving the motor torques the motor and tranny over enough for the cable that is mounted to the chassis to adjust just enough in the selector that is mounted to the tranny to engage the gear. The test is free and would be nice if that was the case before spending money.
Old 08-22-2012, 02:01 PM
I will be watching this thread with interest- the '97 F250HD I picked up recently does just this same thing. Judging from the fact that it does, in fact, bang into gear, and then kick back out, makes me think that the clutches are good, but there's a valve or check ball problem that isn't keeping the pressure on the apply piston for the reverse clutch pack.
I'll do some research into the valve bodies as regards reverse, and if I come up with anything, I'll let you know. Don't hold your breath, I'm a total noob when it comes to slushboxes and I have a lot on my plate, but I want my reverse back! We'll see.
