Are you asking about the two notches on top of the neck of the TC? Those drive part of the pump when installed. Different tranny's have different drive mechanisms. Ours have a keyway like the LPOP others have notches. The common wear seal is the wiper seal that cups the TC neck because they spin against each other. Clean the TC neck real well and inspect it for any roughness or scratches. Real light scratches and roughness you MIGHT get out with 0000 steel wool. If its not perfectly smooth it will damage the new seal quicker. Inspect the seals mating hole in the pump and clean well. The new seal will come with a dry sealant around the metal edge/ring that is supposed to fill in gaps if they present during installation. I will still use a very light coat of gasket maker on the mating surface before install. Install the new seal and put the lightest of coats of grease on the wiping surface (center rubber edge) and the whole TC neck. This will help them come together with less potential damage to the new seal and help it's brake in.
Thanks for the info. So you recommend using gasket sealer between the TC seal and the pump which is sits in? Just making sure i understood that right. I work at a machine shop and we have scotchbright pads (very similar to SOS) that i will use to clear out any scratched on the torque converter.
Also, how do you get that seal out? Im afraid to use a flat head and pry against the pump. I was wondering if there is a better way to do this. Thanks again, Derek |
Yes, very little just to take up any abnormality in the two metal surfaces. Scotch pad is fine as long as its a very fine grit. Your polishing the neck not sanding it.
There is a wiper seal puller at your local parts store. It's cheap, like $6. Don't pry in one place work your way around it. |
Okay thanks for the help! The parts should be getting in today and i'm about to go buy that seal puller.
Look real close at the bushing in the front pump behind the seal. That is what holds the convertor centered. If it's worn it will blow the front seal again in a very short matter of time.
Umm yeah im thinking that bushing is toast.
I wonder how it got this bad?I cant find where to buy this bushing, im still searching |
Usually they come only with the front pump assembly. I can't really see much in the pic other than a few marks on it. But I'd say that if you're not worn through the copper at any point then you should be okay.
